Company name | 상촌인터내쇼날 | Website URL | http://www.sangchon1992.com |
Street address |
Gyeonggi Republic of Korea
[See map] |
Person in charge | - |
Capital | 50,000,000 KRW | Employees | 30 |
Annual sales | 2,500,000,000 KRW | EMIDAS Member Number | 92777 |
Type of manufacturing | Industrial machinery / Machine tools / Measuring machinery |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Automatic lathe |
Development and production of prototype/Small-scale production | NC machining | NC milling NC lathe machining Combined lathe machining |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Complex turning machining Wire machining Screw cutting machining Micro-hole machining Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Automatic screw machining Titanium Fine particle material accepted High precision |
Mass production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Jig grinding Cylindrical mirror grinding Centerless grinding Gear grinding |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Solder (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Rhodium Electroless copper (barrel) Nickel (rack) Tin (rack) Copper (rack) Gold/Silver plating Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (barrel) Electroless copper (rack) Electroless nickel (rack) Electrocasting Chemical conversion coating Tin-zinc alloy plating (rack) Baking (hydrogen embrittling) Trivalent Chromate (barrel plating) Iron Copper Brass Zinc die-cast Aluminum Stainless steel Plastic Other anti-rust treatments Hard chromium (rack) Titanium Magnesium Degreasing Black oxide finish Colored alumite Hard alumite Hot-dip galvanizing (small-size Hot-dip galvanizing (mid-size Hot-dip galvanizing (large-size Dacrotizing Hot-dip aluminum plating Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) Nickel (hoop) solder(Hoop) Tin (hoop) |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing Tool polishing Blade polishing Brush polishing Buffing Mirror polishing |
Surface treatment | Lap polishing | Lap polishing Lap mirror polishing Single-face lapping and polishing Dual-face lapping and polishing |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Quenching Air quenching Salt bath quenching Vacuum quenching Austempering High frequency quenching Flame quenching Solution heat treatment Sub-zero treatment Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Vacuum deposition Other physical vapor deposition methods (PVD) CVD (chemical vapor deposition) Spattering Coating High-speed frame spraying (HVOF) Spraying Resin impregnation Teflon coating Carbide Dispersion/TD Shot peening/WPC Buffing Shot blast Sound blast Water blast Glass beads blast Etching (surface treatment) Ionized plating Thermal oxidation Frame spraying Exploded spray (HEPD) Arc spray Plasma spray Dry type lubricant coating Tool and die coating DLC coating Nylon coating |
Parts manufacturing | Machinery part | Gear manufacturing Shaft and roller manufacturing |
