You can count on us for barrel finishing, sandblasting and other surface technologies!
~We ensure the exact same quality at all times even with a small number of employees.
・Barrel finishing (rotation, vibration, centrifugal, sorting, media, wastewater treatment)
・Blasting (shot method, air method, various abrasives)
・Cleaning (hydrocarbon, ultrasonic oscillation, cleaning solution)
We can also propose a combined treatment, combined blasting, barrel finishing, and cleaning.
Examples of Solutions to Problems
Requests from customers
1. I want to rescue NG parts caused by rust and dirt.
2. Discoloration of the surface due to defects in plating or heat treatment
3. To prevent peeling of plating and coating.
4. Other company's barrel treatment resulted in burrs. I cannot remove the burrs.
5. Rust is generated from the edge of painted parts.
6. Defective coating of die-cast aluminum products. I want to remove the coating and repaint them.
7. Deburring of aluminum die-cast parts is being done in-house by barrel processing, but it takes 25 hours.
8. Burrs appeared on a part with the size of a grain of rice. We want to remove it without affecting anything other than the burr.
9. I want to add a grain to a part of a resin molding die.
10. The part is difficult to be removed from the resin mold and the work efficiency is poor.
We can solve all of these problems for you!
Company name | NAGANO HIDAKA (Thailand) Co., Ltd. | EMIDAS Member Number | 92627 |
Country | Kingdom of Thailand | Street address |
Amphur Bang Sao Thong Samut Prakan Kingdom of Thailand |
Telephone number | +66-66-2-182-5273 | Fax number | +66-66-2-182-5275 |
Employees | 2,000,000 THB | Annual sales | |
Employees | 8 | Person in charge | Kitazawa |
Primary clients |
