NC cylindrical grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Plane grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Cylindrical grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Rotary grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
High precision( Mass production / Mechanical processing ) |
Hard chrome (barrel)( Surface treatment / Plating/Chemical conversion treatment ) |
Zinc (barrel)( Surface treatment / Plating/Chemical conversion treatment ) |
Company name |
株式会社 相模鍍研 (Sagamitokenn) |
Website URL | http://www.sagamitoken.com/ |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 8,000,000 JPY | Employees | 13 |
Annual sales | Unregister | EMIDAS Member Number | 92514 |
Large | Medium | Small |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining NC vertical lathe Combined lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Cylindrical grinding Jig grinding Internal grinding NC internal grinding Rotary grinding |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Complex turning machining Wire machining Iron Stainless Aluminum alloy High precision |
Surface treatment | Plating/Chemical conversion treatment | Zinc (barrel) Zinc (rack) Electroless nickel (barrel) Electroless nickel (rack) Iron Aluminum Stainless steel Hard chromium (rack) Black oxide finish Hard alumite Hot-dip galvanizing (mid-size Hot-dip galvanizing (large-size Electroless nickel (large) Hard chrome (barrel) Hard chrome (large) |
