PR message
Found in 2005, LPC Exact Mechanical and Joint Stock Company has 13 years of experience working with Japanese customers. Our main strengths are: manufacturing CNC machining parts, designing and manufacturing jigs and moulds. We can take MTO orders of large quantity and urgent delivery date. Please do not hesitate to send us inquiry for catalog or quotation, we will fulfill your request within 24 hours.
Products that are easily scratched after processing require a protective film to be applied to the product.
The machine is integrated with a camera system to determine the position of the product and film to automatically adjust the position before matching the gluing position and rolling to remove air bubbles.
The products are processed with high precision to meet customers' strict technical requirements.
For details, please visit:
https://vi.nc-net.or.jp/company/92086/dl/catalog/k/e7f3576d6197fdbf07174766fa00c947
Contact information:
http://lpc.com.vn/
0355178317
vanvth79@lpc.com.vn
After processing, products need to be checked for air tightness and whether there is air leakage or not.
The machine is integrated with a specialized air leak checker, so it can detect very small air leaks based on the difference in air pressure compared to the standard. The machine can be used in many applications in the field of manufacturing watch components, phones, cameras...
http://lpc.com.vn/
0355178317
vanvth79@lpc.com.vn
In assembly lines, loading and tightening screws takes up a lot of labor and time. These types of machines help to automatically load and tighten screws at required assembly locations on the product, helping to reduce machine cycle time and reduce labor.
The system combines an automatic screw gun with a 3-axis robot and positioning by high-precision cameras, helping to load and tighten screws seamlessly, quickly and accurately.
The machine is used in many fields, especially in the field of electronics.
Machine size: 1500x1000x1600 mm
http://lpc.com.vn/
0355178317
vanvth79@lpc.com.vn
This machine uses a 6-axis robot arm to flexibly pick and place products into designated trays.
It is is combined with an inspection system that accurately distinguishes the tip of the product and turns it in the correct direction.
In addition to the loader function, the machine can perform many other functions at the request of the customer before entering the main process such as cleaning, peeling tape, checking product ID.
This machine can be used in many fields, especially in the field of electronics.
Machine size: 1100x1300x1500mm
http://lpc.com.vn/
0355178317
vanvth79@lpc.com.vn
These products are applied in the electronics industry, especially the phone industry, with high precision. They can meet various demands such as:
- Keyboard membrane mounting jig
- Speaker assembly jigs fors
- Screwing/unscrewing jigs
- LCD assembling and pressing jigs...
Surface treatment (depending on material): heat treatment, anode, black dyeing, chrome/nickel plating...
http://lpc.com.vn/
0355178317
vanvth79@lpc.com.vn
Jig components made in a wide variety of materials used in mechanical production according to customers' technical requirements.
http://lpc.com.vn/
0355178317
vanvth79@lpc.com.vn
Block master product series used for checking accuracy of other jigs
http://lpc.com.vn/
0355178317
vanvth79@lpc.com.vn
Mold and die inserts - for punching molds, hot stamping molds.
The products can be applied in various manufacturing fields, for example: washing machines, phone cases... .
http://lpc.com.vn/
0355178317
vanvth79@lpc.com.vn
Company name | LPC Exact Mechanical and Trading Joint Stock Company | Website URL | http://www.lpc.com.vn/ |
Street address |
Hanoi Ha Noi Socialist Republic of Vietnam
[See map] |
Person in charge | Pham Dang Lam |
Telephone number | 0355178317 | Fax number | 02463266205 |
Capital | 2,000,000 $ | Employees | 80 |
Annual sales | Unregister | EMIDAS Member Number | 92086 |
Type of manufacturing | Jigs and tools / Machine tools / Industrial machinery | ||
Main 3 products |
Large | Medium | Small |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
