Most recent update: 2022-01-20
Company name |
伊藤忠テクノソリューションズ 株式会社 (Itouchuutekunosoryu-shonnzu) |
Website URL | http://www.ctc-g.co.jp/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 21,763,000,000 JPY | Employees | 8385 |
Annual sales | Unregister | EMIDAS Member Number | 92011 |
Type of manufacturing | Machine tools / Industrial machinery |
Large | Medium | Small |
Designing | Simulation | Cutting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Additional-axis machining NC milling NC lathe machining 5-face/5-axis machining Five-face machining Boring milling NC facing NC vertical lathe Combined lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Form grinding Cylindrical grinding Internal grinding NC internal grinding Double-sided grinding |
Mass production | Mechanical processing | Iron Stainless Cemented carbide Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Sintered metal Turning machining(plastic) Casting Titanium Diamond |
Mass production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Internal grinding NC internal grinding Double-sided grinding |
Parts manufacturing | Machinery part | Gear manufacturing Valve manufacturing Bearing manufacturing Pressure container manufacturing Connection parts manufacturing Crank shaft manufacturing Optical parts manufacturing Shaft and roller manufacturing pipe manufacturing Ring |
Parts manufacturing | Other parts | Blade manufacturing |
Auto parts manufacturing | Body part | Door Grill Bumper Fender Door mirror Door lock Other body parts |
Auto parts manufacturing | Drive system part | Accelerator Clutch Steering device Drive shaft Brake parts |
Auto parts manufacturing | Engine | Cooling system Ignition system Fuel system Muffler Radiator parts |
Product manufacturing | Plant equipment manufacturing | Steel and furnace apparatus manufacturing |
