Part processing( Die manufacturing / Plastic mold ) |
Company name | 株式会社リュウコク | Website URL | https://www.ryu-koku.com/ |
Street address |
Hyogo Japan
[See map] |
Person in charge | - |
Capital | 1,000,000 RMB | Employees | 10 |
Annual sales | Unregister | EMIDAS Member Number | 91803 |
Large | Medium | Small |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Injection molding die Blow molding die Extrusion molding die Below 60 t 60 - 300 t 000 t |
Die manufacturing | Rubber mold | Designing Rubber mold part processing Part processing Packing-related products binoculars and optical products |
Die manufacturing | Casting die | Designing Manufacturing Die-casting part processing NC data creation 3D modeling Die-casting die Shell moulding die Lost-wax casting die Sand casting die Wooden model |
Mass production | Mechanical processing | NC milling machining NC turning machining Tapping machining Gear cutting machining Electrical discharge machining Spinning Iron Stainless Aluminum alloy Copper alloy Automatic screw machining Turning machining(plastic) Casting Fine particle material accepted Clad |
Mass production | Plastic | Blow molding Extrusion molding Insert molding Engineering plastic PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) PEEK (polyetheretherketone) Elastomer Below 60 t 60 - 300 t 000 t Injection molding Handles small-scale production |
Mass production | Die-casting | 125 t or less 125 - 250 t Aluminum |
