Simultaneous 5-axis machining( Development and production of prototype/Small-scale production / Machining ) |
Handles 3D processing( Development and production of prototype/Small-scale production / NC machining ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
General jig manufacturing( Development and production of prototype/Small-scale production / Jig manufacturing ) |
Die-casting part processing( Die manufacturing / Casting die ) |
Company name |
株式会社呉匠 (Kureshou) |
Website URL | http://kuresho.com/ |
Street address |
Hiroshima Japan
[See map] |
Person in charge | - |
Capital | 46,000,000 JPY | Employees | 22 |
Annual sales | 280,000,000 JPY | EMIDAS Member Number | 91777 |
Type of manufacturing | Heavy electric machinery / Industrial machinery / Transportation equipment |
Large | Medium | Small |
Designing | Product and part designing | Measurement/testing device designing |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing General-purpose jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Thread-cutting Profile milling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Machining (resin) Sintered metal Sintered metal Keyway milling Automatic lathe Simultaneous 5-axis machining Milling (resin) Lathe machining (resin) Casting Handles microfabrication Handles microfabrication Titanium Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Additional-axis machining NC milling NC lathe machining Combined lathe machining Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing Aluminum die-casting prototype mold |
Die manufacturing | Press die | Part processing |
Die manufacturing | Plastic mold | Part processing |
Die manufacturing | Rubber mold | Part processing |
Die manufacturing | Powder metallurgy mold | Powder metallurgy mold part manufacturing |
Die manufacturing | Forging die | Forging die part processing |
Die manufacturing | Casting die | Die-casting part processing |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Electroless copper (barrel) Nickel (rack) Tin (rack) Gold/Silver plating Chromium (rack) Black chromium (rack) Zinc (rack) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (barrel) Electroless copper (rack) Electroless nickel (rack) Chemical conversion coating Trivalent Chromate (barrel plating) Iron Copper Brass Aluminum Stainless steel Other anti-rust treatments Hard chromium (rack) Degreasing Black oxide finish Colored alumite Hard alumite Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) Hard chrome (barrel) |
Surface treatment | Coating | Air-spray coating Powder coating Resin coating Electrodeposition coating Metal coating |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Quenching Air quenching Vacuum quenching High frequency quenching Flame quenching Solution heat treatment Sub-zero treatment Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Spraying Teflon coating Buffing Sound blast Etching (surface treatment) Deburring |
Assembly/Inspection | Side job processing | Manual labor |
Parts manufacturing | Machinery part | Gear manufacturing Valve manufacturing Vacuum components manufacturing Pressure container manufacturing Connection parts manufacturing Crank shaft manufacturing Optical parts manufacturing Shaft and roller manufacturing pipe manufacturing Ring Mechanical parts |
Parts manufacturing | Bolt/Screw/Nut | Bolt/Screw/Nut manufacturing Screw manufacturing Bolt manufacturing Nut manufacturing Screw manufacturing |
Auto parts manufacturing | Body part | Other body parts |
Product manufacturing | Household commodity | Outdoor leisure product manufacturing |
Product manufacturing | Furniture/Interior | Nameplates |
