NC milling machining( Mass production / Mechanical processing ) |
Robot welding( Mass production / Welding / welding ) |
Turret punch punching( Mass production / Blank cutting ) |
Housing manufacturing( Mass production / Sheet-metal processing ) |
TIG welding (argon welding)( Mass production / Welding / welding ) |
Robot welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Can-making( Mass production / Sheet-metal processing ) |
Company name |
株式会社 三和製作所 (Sannwaseisakusho) |
Website URL | http://sanwa-s.jp/ |
Street address |
Toyama Japan
[See map] |
Person in charge | - |
Capital | 40,000,000 JPY | Employees | 200 |
Annual sales | Unregister | EMIDAS Member Number | 91605 |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling Tapping Thread-cutting Profile milling Straightening Machining/Handles small-scale production (order from 1 piece) Aluminum alloy Router machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Chassis manufacturing Sheet metal protocol manufacturing Angle machining Deburring Coating Bending (hydraulic) Bending (servo) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Corner shearing Thin plate (below 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining Drawing die Blanking die Single press die Below 60 t Sash molding die |
Mass production | Metal press | Drawing Bending Blanking Aluminum Thickness Thickness Single press (80 - 200 t) |
Mass production | Mechanical processing | NC milling machining Tapping machining Aluminum alloy |
Mass production | Sheet-metal processing | Can-making Housing manufacturing Sheet metal prototype manufacturing Angle processing Deburring process Painting process Bender processing (flood control) Bender processing (servo) Bending process |
Mass production | Blank cutting | Turret punch punching Shirring Cutting process Connor Shah stainless Copper / aluminum |
Mass production | Welding / welding | Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding |
Assembly/Inspection | Assembly | Construction component assembly |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
