Progressive die( Die manufacturing / Press die ) |
Company name |
AJATO CO.,LTD () |
Website URL | http://ajato.com.tw/ |
Street address |
Republic of China (Taiwan)
[See map] |
Person in charge | - |
Capital | 13,000,000 JPY | Employees | 120 |
Annual sales | Unregister | EMIDAS Member Number | 91514 |
Type of manufacturing | Electronic parts |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing General metal press die |
Development and production of prototype/Small-scale production | Machining | General-purpose lathe machining Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Nickel alloy Automatic lathe Handles microfabrication Brass |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Sheet metal protocol manufacturing Deburring Thin wall (Thickness |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending prototype mold |
Die manufacturing | Press die | Designing Manufacturing Part processing Drawing die Bending die Blanking die Forming die Multi forming die Progressive die Single press die Below 60 t 60 - 300 t |
Mass production | Metal press | Drawing Bending Blanking Multi forming Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Corson alloy Beryllium copper Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Chromium (barrel) Zinc (barrel) Gold/Silver plating Zinc (rack) Alumite (anode oxidation) Acid pickling Aldine treatment (aluminum chromate) Electroless nickel (barrel) Electroless nickel (rack) Baking (hydrogen embrittling) Trivalent Chromate (barrel plating) Iron Copper Brass Aluminum Stainless steel Other anti-rust treatments Titanium Degreasing Black oxide finish Unichromate (white) Colored chromate (multi-color) Nickel (hoop) Gold(Hoop) Tin (hoop) |
Assembly/Inspection | Assembly | Precision equipment assembly Auto parts assembly Toy and sundries assembly |
Assembly/Inspection | Inspection | Metal press |
Assembly/Inspection | Side job processing | Manual labor |
