Most recent update: 2020-07-29
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
有限会社 南栄工業 (Yuugenngaisha nanneikougyou) |
Website URL | http://www.nanei-spi.co.jp/ |
Street address |
Okayama Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 12 |
Annual sales | Unregister | EMIDAS Member Number | 91310 |
Type of manufacturing | Not selected / Not selected / Not selected |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Thread-cutting |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating Bending (hydraulic) Bending (servo) Can manufacturing (over 5 m) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting Corner shearing Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding TIG welding (argon welding) Arc welding |
Development and production of prototype/Small-scale production | Jig manufacturing | Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending |
Surface treatment | Coating | Air-spray coating |
Surface treatment | Heat treatment | Straightening annealing Quenching |
Assembly/Inspection | Assembly | Construction component assembly Industrial machinery assembly |
Assembly/Inspection | Inspection | Forging |
Assembly/Inspection | Side job processing | Manual labor |
Product manufacturing | Plant equipment manufacturing | Steel and furnace apparatus manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Pipe connection |
