Precision sheet metal processing( Mass production / Sheet-metal processing ) |
Laser and turret punch punching( Mass production / Blank cutting ) |
Turret punch punching( Mass production / Blank cutting ) |
Thin plate (below 6 mm)( Development and production of prototype/Small-scale production / Blank cutting ) |
Bending process( Mass production / Sheet-metal processing ) |
TIG welding (argon welding)( Mass production / Welding / welding ) |
Robot welding( Mass production / Welding / welding ) |
Company name |
ケーズメタル 株式会社 (Ke-zumetaru) |
Website URL | http://ks-metal.co.jp/ |
Street address |
Toyama Japan
[See map] |
Person in charge | - |
Capital | 23,000,000 JPY | Employees | 30 |
Annual sales | Unregister | EMIDAS Member Number | 91212 |
Type of manufacturing | Machine tools / Industrial machinery / Telecommunication equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing NC set press Precision sheet metal machining Angle machining Deburring Hair line machining Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Cutting Laser and turret punch press processing Thin plate (below 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Robot welding Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending |
Mass production | Sheet-metal processing | NC set press Precision sheet metal processing Sheet metal prototype manufacturing Deburring process Hairline processing Bender processing (flood control) Bender processing (servo) Bending process |
Mass production | Blank cutting | Turret punch punching Cutting process Laser and turret punch punching Connor Shah CO2 laser processing Clean cut Thin plate 6 mm or less stainless Copper / aluminum |
Mass production | Welding / welding | CO2 welding Spot welding TIG welding (argon welding) Robot welding Stud welding |
