PR message
We serve the needs of the growing market in the industrial use of special steel ; with specifications to DIN, EN, ASTM, AISI, BS, JIS and other equivalent standards..
COLD WORK & HOT WORK TOOL STEELS
PLASTIC MOULD STEELS
HIGH SPEED STEELS
STAINLESS STEELS
AISI 4140HT : PRE-HARDENED MEDIUM ALLOY STEEL, WITH HIGH TENSILE STRENGTH.
AISI 4340HT; PRE-HARDENED NICKEL MEDIUM ALLOY STEEL, WITH EXTRA HIGH TENSILE STRENGTH.
DIN 1.5918/1.5919 : NICKEL CHROMIUM MOLYBDENUM LOW CARBON STEEL, SUIT FOR CASE HARDENING BY CARBURIZING
DIN ST52-3 : LOW CARBON, HIGH STRENGTH STRUCTURAL STEEL WITH GOOD WELDING AND BENDING PROPERTIES.
SCM 440 : UNTREATED MEDIUM ALLOY STEEL, FOR GENERAL MACHINERY PARTS.
AR 400V is a wear resistant steel with an average hardness of 400 HBW in delivery condition whose mechanical properties are obtained by quenching. AR 400V is successfully applied where elevated resistance to wear is required together with good workability and especially good weldability.
Earth moving and loading machines, dredgers, skip cars, conveying plants, trucks, cutting edges, knives and breakers, waste elimination and recycling plants.
EH 36 High strength structural steel plate intended primarily for using in ship construction with third’s party certified such as LLoyd’s or ABS’s register. With its low carbon equivalent, fully killed and fine grain, it possesses good cold forming and good weld properties.
These products have been extensively used for ship buildings, offshore and marine structures, storage tank, bridges, mobile equipment, crane, boom, chassis, etd. For service at ambient and low temperature.
Company name | LEONG JIN SPECIAL STEEL (THAILAND) CO., LTD. | Website URL | |
Street address |
Moo 17, Taeparak Rd., Bangsaothong Samut Prakan Kingdom of Thailand
[See map] |
Person in charge | Pongsakorn Thaipatanagul |
Telephone number | +66-2705-0930 | Fax number | +66-2315-1354 |
Capital | 3,100,000 $ | Employees | 81 |
Annual sales | Unregister | EMIDAS Member Number | 90513 |
Main 3 products |
