PR message
Long Thanh GMT Viet Nam specializes in the field of mold and jig manufacturing, automatic and semi-automatic machinery,CNC lathe, and milling mass production.
Our main customers are Japanese companies. With a team of highly-skilled, experienced engineers, synchronous machine systems, production processes as the ISO standard 9001-2015, 5S, and so
on, we always satisfy the customer demand, even strict customers.
We handle from low volume to high volume production qty for product mix. Our suppliers use different CAD-CAM software so we can handle any format of product data for machining.
Materials we offer – Carbon Steels, Stainless steel, Alloy Steels, Aluminum, Brass, Plastic and any other materials as per customer requirement.
We also offer secondary operations like finish process (various plating/passivation/corrosion prevention etc) and heat treatment as per customer specifications for above material.
Mass production jig designing( Designing / Jig and tool designing ) |
Company name | LONG THANH GMT VIETNAM JOINT STOCK COMPANY | Website URL | http://www.longthanhgmt.com.vn |
Street address |
Hoai Duc Ha Noi Socialist Republic of Vietnam
[See map] |
Person in charge | KHAC THUY LE |
Telephone number | +-965280888-0986628159 | Fax number | +-24-62912377 |
Capital | 20,000,000,000 VND | Employees | 60 |
Annual sales | 50,000,000,000 VND | EMIDAS Member Number | 90209 |
Type of manufacturing | Jigs and tools / Machine tools / Electronic parts | ||
Main 3 products |
Large | Medium | Small |
Designing | Mold designing | Forging die designing Casting die designing Injection molding die Drawing metal press die designing Transfer press die designing General metal press die Extrusion molding die designing Porous plastic die |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Designing | Industrial equipment designing | Automatic machinery manufacturing |
Development and production of prototype/Small-scale production | Machining | Melt cutting Tapping Plano miller machining Deep hole drilling Thread-cutting Straightening Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Broaching Automatic lathe Milling (resin) Air chuck equipment Lathe machining (resin) Casting Handles microfabrication Honing pipe manufacturing Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Five-face machining Boring milling NC facing NC vertical lathe Combined lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Jig grinding |
Die manufacturing | Press die | Designing Die set machining Bending die Blanking die Forming die Fine blanking die Multi forming die Roll forming die Transfer press die |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing 3D modeling Core and cavity machining |
Die manufacturing | Casting die | Designing Die-casting part processing Die-casting die |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining |
Mass production | Plastic | Engineering plastic |
