Gravity casting( Mass production / Casting ) |
Sand casting ( Mass production / Casting ) |
Sand casting( Development and production of prototype/Small-scale production / Casting ) |
Machining( Mass production / Mechanical processing ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Casting die designing( Designing / Mold designing ) |
Company name |
光軽金属工業株式会社 (Hikarikeikinnzokukougyou ) |
Website URL | http://www.hikari-light-metals.co.jp |
Street address |
Okayama Japan
[See map] |
Person in charge | - |
Capital | 90,000,000 JPY | Employees | 122 |
Annual sales | 3,200,000,000 JPY | EMIDAS Member Number | 89634 |
Type of manufacturing | Industrial machinery / Machine tools / Transportation equipment |
Large | Medium | Small |
Designing | Mold designing | Casting die designing |
Designing | Test | Destructive test Nondestructive test |
Designing | Simulation | 3D modeling CAE fluid analysis Thermal analysis Casting Heat treatment |
Designing | Data creation (3D scan) | 3D printer Data creation (3D scan) |
Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) Aluminum alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Prototype processing | Aluminum die-casting |
Development and production of prototype/Small-scale production | Casting | die-cast Shell mold Gravity casting Sand casting Aluminum alloy 500g or less 500g-5kg 5kg or more |
Die manufacturing | Casting die | Designing |
Mass production | Mechanical processing | Machining NC turning machining Aluminum alloy High precision |
Mass production | Die-casting | 125 t or less 125 - 250 t 000 t 000 t Aluminum Zinc |
Mass production | Casting | Gravity casting Sand casting Aluminum alloy Over 500 g and less than 5 kg 5 kg and over |
Surface treatment | Heat treatment | Solution heat treatment |
Assembly/Inspection | Inspection | Casting |
Auto parts manufacturing | Drive system part | Steering device |
Auto parts manufacturing | Engine | Radiator parts |
