Most recent update: 2019-10-08
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
有限会社 天ヶ瀬工業 (Amagasekougyou) |
Website URL | |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 36 |
Annual sales | 520,000,000 JPY | EMIDAS Member Number | 89516 |
Type of manufacturing | Machine tools / Industrial machinery / Construction material |
Large | Medium | Small |
Designing | Simulation | Welding Structure |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Precision sheet metal machining Chassis manufacturing Bending (hydraulic) Can manufacturing (over 5 m) |
Development and production of prototype/Small-scale production | Blank cutting | Cutting Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Mass production | Metal press | Bending Iron Stainless steel Aluminum Thickness Transfer press (80 - 200 t) |
Mass production | Mechanical processing | Machining Tapping machining Screw cutting machining Iron Stainless Aluminum alloy Ultra-thin |
Surface treatment | Cleaning | Shower-type cleaning |
Surface treatment | Coating | Air-spray coating Lacquer coating |
Assembly/Inspection | Assembly | Construction component assembly Industrial machinery assembly |
Assembly/Inspection | Repair | Industrial machinery repair |
Assembly/Inspection | Side job processing | Manual labor |
Product manufacturing | Construction and civil engineering machinery manufacturing | Civil engineering machinery manufacturing Construction and civil engineering material manufacturing Construction machinery manufacturing |
