Most recent update: 2023-12-22
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
双葉電子工業 株式会社 (Futabadennshikougyou) |
Website URL | http://www.futaba.co.jp |
Street address |
Chiba Japan
[See map] |
Person in charge | - |
Capital | 22,558,000,000 JPY | Employees | 1426 |
Annual sales | 58,100,000,000 JPY | EMIDAS Member Number | 89266 |
Type of manufacturing | Jigs and tools / Measuring machinery / Electronic parts |
Large | Medium | Small |
Material | Steel component distribution | Stainless steel Tool steel Free-machining steel Other steel plates and straps Flat steel plate |
Material | Nonferrous metal distribution | Flat steel plate |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling Tapping Deep hole drilling Thread-cutting Profile milling Straightening Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Keyway milling Simultaneous 5-axis machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling 5-face/5-axis machining Five-face machining Boring milling Machining (horizontal) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Jig boring Jig grinding Rotary grinding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Small-size prototype manufacturing Sheet lamination Prototype/Small-lot molding Simplified/Molding prototype mold |
Die manufacturing | Press die | Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Blanking die Single press die Below 60 t Compound die |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Plate machining Mold base machining NC data creation 3D modeling Expansion molding die Below 60 t Cassette-type molding die Core and cavity machining |
Die manufacturing | Cutting dies | Thomson punch |
Mass production | Metal press | Drawing Blanking Stainless steel Aluminum Copper Thickness Single press (below 80 t) |
Mass production | Plastic | Biodegradable plastic |
Surface treatment | Plating/Chemical conversion treatment | Other anti-rust treatments |
Surface treatment | Polishing/Lapping | Mirror polishing |
Surface treatment | Heat treatment | Normalizing Annealing Stress relief annealing (SR treatment) Quenching Salt bath quenching High frequency quenching Sub-zero treatment Nitridation |
Product manufacturing | Production property | Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing |
