Most recent update: 2024-03-06
Injection molding die( Designing / Mold designing ) |
NC milling ( Development and production of prototype/Small-scale production / NC machining ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
タカラ工業株式会社 (Takarakougyou) |
Website URL | http://www.takara.jp.net |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 80 |
Annual sales | Unregister | EMIDAS Member Number | 89182 |
Type of manufacturing | Machine tools / Jigs and tools / Industrial machinery |
Large | Medium | Small |
Designing | Mold designing | Injection molding die General metal press die 3D modeling (plastic) NC data creation (plastic) |
Designing | Jig and tool designing | Welding jig designing |
Material | Steel component distribution | Pickled steel plate Stainless steel Tin Other steel plates and straps Steel (round) bar |
Material | Nonferrous metal distribution | Others |
Material | Plastic material distribution | PS (polystyrene) PC (polycarbonate) POM (polyoxymethylene) Fluororesin GFRP (glass fiber reinforced plastic) PU (polyurethane) |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Thread-cutting Straightening Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Keyway milling Automatic lathe Milling (resin) Urethane |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Cutting Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing Laser marking Thick plate (over 6 mm) Stainless steel Other resins |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding |
Development and production of prototype/Small-scale production | Jig manufacturing | Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Welding Bending Small-size prototype manufacturing Prototype/Small-lot molding Small-lot/Injection molding Simplified/Molding prototype mold |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Bending die Blanking die Single press die 60 - 300 t |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Mold base machining NC data creation 3D modeling 60 - 300 t 000 t Core and cavity machining |
Die manufacturing | Rubber mold | Designing |
Mass production | Metal press | Bending Blanking |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Wire machining Screw cutting machining Micro-hole machining Electrical discharge machining Iron Stainless Aluminum alloy Automatic screw machining Turning machining(plastic) High precision |
Mass production | Plastic | Insert molding General-purpose material PMMA (polymethyl methacrylate) GFRP (glass fiber reinforced plastic) Urethane resin 60 - 300 t Injection molding Handles small-scale production |
Mass production | Grinding processing | NC plane grinding |
Mass production | Sheet-metal processing | Can-making Bender processing (servo) |
Mass production | Welding / welding | CO2 welding Spot welding TIG welding (argon welding) Arc welding |
Surface treatment | Printing and others | Silk screen printing |
Surface treatment | Heat treatment | Quenching |
Assembly/Inspection | Assembly | Precision equipment assembly Office equipment assembly Auto parts assembly Construction component assembly Industrial machinery assembly Toy and sundries assembly |
Assembly/Inspection | Repair | Auto parts repair Construction repair Die repair |
