Medical equipment manufacturing( Product manufacturing / Medical equipment manufacturing ) |
Complex turning machining( Mass production / Mechanical processing ) |
Machining( Mass production / Mechanical processing ) |
Five-face/axes machining( Mass production / Mechanical processing ) |
Automatic screw machining( Mass production / Mechanical processing ) |
NC milling machining( Mass production / Mechanical processing ) |
NC turning machining( Mass production / Mechanical processing ) |
Company name |
株式会社 佐文工業所 (Sabunnkougyousho) |
Website URL | http://www.sabun.co.jp/ |
Street address |
Niigata Japan
[See map] |
Person in charge | - |
Capital | 36,200,000 JPY | Employees | 260 |
Annual sales | Unregister | EMIDAS Member Number | 89122 |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose lathe machining Thread-cutting Stainless steel Aluminum alloy Copper alloy Titanium alloy Machining (resin) Sintered metal Automatic lathe Simultaneous 5-axis machining Milling (resin) Titanium Sintered metal Handles microfabrication Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Five-face machining Combined lathe machining Handles 3D processing |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Wire machining Screw cutting machining Micro-hole machining Electrical discharge machining Iron Stainless Aluminum alloy Copper alloy Titanium alloy Nickel alloy Sintered metal Automatic screw machining Air chuck equipment Turning machining(plastic) Titanium Fine particle material accepted |
Surface treatment | Plating/Chemical conversion treatment | Black oxide finish |
Surface treatment | Polishing/Lapping | Buffing |
Surface treatment | Heat treatment | Carburized quenching |
Surface treatment | Barrel polishing | Barrel finishing (vibration) |
Assembly/Inspection | Assembly | Precision equipment assembly |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
