Automobile (trial production)
Machine tools
Construction machinery parts
In house assembled oversize carburizing machine.
[Main Product] Bearing race, large size internal gear, large size gear
✔ Max. φ1800×(H)400mm
[Material] Carbon steel (S45C), Stainless steel (SUS304)
[Single Quench]
For transfer quenching, starting and ending point of heating and cooling overlaps leading to cracks or reduced hardness.
With Fuji Electronic all around single shot quenching, a complete uniformed quenching layer can be produced even a slewing ring size of diameter of 1.8m and module of 15. Also, comparing to transfer quenching, improved productivity, 1/5 work speed, and 1/2 ~ 1/3 electricity consumption.
[Carburizing]
Once the heating process has completed, by simultaneously dipping the product into the cooling water and blasting water current through jackets, helps to prevent from entering while forming a uniformed quenched layer.
In addition, by controlling quenching water temperature and stir speed, an effect layer can be controlled precisely.
[Inner and Outer Diameter Simultaneously Heating]
By having two electrical switches on both sides, the inner and outer layer can be quenched simultaneously with low distortion.
Company name | Fuji Electronics Industry Co., Ltd. | EMIDAS Member Number | 88995 |
Oihara, Yao Osaka Japan |
Telephone number | +-72-991-1361 | Fax number | +-72-991-1309 |
Employees | 80,000,000 JPY | Annual sales | |
Employees | 130 | Person in charge | Noumi |
Type of manufacturing | Machine tools / Industrial machinery / Transportation equipment | ||
Primary clients |
