Most recent update: 2023-05-31
Handles microfabrication( Development and production of prototype/Small-scale production / Machining ) |
Company name |
株式会社 鈴木 (Suzuki) |
Website URL | http://www.suzukinet.co.jp/ |
Street address |
Nagano Japan
[See map] |
Person in charge | - |
Capital | 1,435,300,000 JPY | Employees | 1086 |
Annual sales | Unregister | EMIDAS Member Number | 88701 |
Type of manufacturing | Industrial machinery / Electronic parts / Electrical component for transportation equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Thread-cutting Profile milling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Keyway milling Automatic lathe Casting Handles microfabrication Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Boring milling Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Form grinding Profile grinding Jig boring Jig grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | YAG laser machining |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Bending Small-size prototype manufacturing Chassis prototype manufacturing Prototype/Small-lot molding Small-lot/Injection molding Simplified/Molding |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation 3D modeling Drawing die Bending die Blanking die Forming die Fine blanking die Multi forming die Roll forming die Shaving die Progressive die Transfer press die Single press die Below 60 t 60 - 300 t |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Plate machining Mold base machining NC data creation 3D modeling Injection molding die Insert molding die Below 60 t Electrode manufacturing Cassette-type molding die Thin wall injection molding die Injection molding die for microfabrication (5 mm or smaller) Core and cavity machining |
Die manufacturing | Forging die | Designing Manufacturing Forging die part processing Cold forging die Press forging die |
Mass production | Metal press | Drawing Bending Blanking Forming Shaving Coining Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness Combined press-joining Corson alloy Beryllium copper Single press (80 - 200 t) Progressive press (35 - 80 t) |
Mass production | Plastic | Insert molding General-purpose material LCP (liquid crystal polymer) Below 60 t Injection molding Thin wall molding |
Mass production | Forging | Cold forging Press forging Iron Aluminum Brass Below 500 g |
Surface treatment | Plating/Chemical conversion treatment | Gold/Silver plating Copper Brass |
Surface treatment | Heat treatment | Normalizing Annealing Quenching Sub-zero treatment |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Assembly/Inspection | Inspection | Metal press Plastic Forging |
Parts manufacturing | Electrical part | Connector manufacturing |
Product manufacturing | Production property | Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Semiconductor manufacturing equipment manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
