Single press (below 80 t)( Mass production / Metal press ) |
Thickness: 0.2 mm - 3.2mm( Mass production / Metal press ) |
CO2 laser machining ( Development and production of prototype/Small-scale production / Blank cutting ) |
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
3-roll bending( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
General metal press die( Designing / Mold designing ) |
Bending (servo)( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
CO2 welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Aluminum( Mass production / Metal press ) |
Company name |
株式会社 前田テクニカ (Maedatekunika) |
Website URL | http://www.maeda-technica.co.jp |
Street address |
Mie Japan
[See map] |
Person in charge | - |
Capital | 8,000,000 JPY | Employees | 40 |
Annual sales | Unregister | EMIDAS Member Number | 88354 |
Large | Medium | Small |
Designing | Mold designing | General metal press die |
Development and production of prototype/Small-scale production | Machining | General-purpose milling |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Deburring 3-roll bending Bending (hydraulic) Bending (servo) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing CO2 laser machining Thin plate (below 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing Simplified/Molding |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Drawing die Bending die Blanking die Progressive die Single press die Below 60 t 60 - 300 t Compound die |
Mass production | Metal press | Bending Blanking Shaving Coining Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness Single press (below 80 t) Single press (80 - 200 t) |
Assembly/Inspection | Inspection | Measuring |
