Most recent update: 2021-11-18
Bending( Mass production / Metal press ) |
Company name |
株式会社 辻本金属製作所 (Tsujimotokinnzokuseisakusho) |
Website URL | |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 28,000,000 JPY | Employees | 30 |
Annual sales | Unregister | EMIDAS Member Number | 88065 |
Type of manufacturing | Construction material |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Iron Stainless steel Titanium Brass |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Chassis manufacturing Bending (hydraulic) |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Arc welding Brazing |
Development and production of prototype/Small-scale production | Prototype processing | Bending |
Mass production | Metal press | Bending Blanking |
Mass production | Mechanical processing | Machining NC turning machining Tapping machining Wire machining Screw cutting machining Electrical discharge machining Automatic screw machining |
Surface treatment | Plating/Chemical conversion treatment | Nickel (rack) Copper (rack) Chromium (rack) Black chromium (rack) Zinc (rack) Nickel chromium (rack) Trivalent Chromate (barrel plating) Hard chromium (rack) Unichromate (white) |
Surface treatment | Coating | Resin coating Urethane coating Acrylic coating Ceramic coating Epoxy coating |
Surface treatment | Other surface treatment | Coating Buffing Shot blast |
Assembly/Inspection | Assembly | Construction component assembly |
