A high vacuum die casting method during the helps to prevent blowholes from occurring. The high vacuum casting method uses a technique where a vacuum is drawn for the die cavity reducing the pressure and thereby reducing the number of air bubbles that existed initially. If the amount of gas that forms the trapped pores is reduced, you can improve the major pores that are trapped. In addition, you can also make the runs better because there is very little gas that materializes in the filler flow.
This technology is rarely seen in small to medium-sized or medium-scale die cast manufacturers. However, it is used not only in the automotive industry but in pumps, etc., for industrial machinery.
We currently receive orders for parts from a wide range of fields and strive to deliver sound casting products to our customers. In addition, with our a quality assurance system, which which carries out tasks such as our X-ray fluoroscopic inspection, and we have also achieved a high level QCD that has been developed from our experience in the automotive industry.
Company name | Akiba Die Casting Co.,Ltd. | EMIDAS Member Number | 88036 |
Takasaki-shi Gunma Japan |
Telephone number | +81-27-361-4499 | Fax number | +81-27-361-9904 |
Employees | 20,000,000 JPY | Annual sales | |
Employees | 118 | Person in charge | Masao Akiba |
Type of manufacturing | Transportation equipment / Electrical component for transportation equipment / Industrial machinery |
