Machine tool
Internal Grinding
Internal grinding is also one of our strengths, we are proud of our ID grinding capabilities on objects with an internal diameter as small as 1 mm.
we have perfectioned our inner grinding abilities using a brace as support.
we can achieve a precision concentricity up to 0.002 mm.
we can offer grinding of objects with a length up to 1500 mm, the length of the whetstone axis will change depending on the internal depth of the part to be ground.
At customer order, we can provide an inspection protocol sheet based on the measurements done from our on-site quality department using the roundness measuring machine.
Company name | OHORI GRINDING COMPANY | EMIDAS Member Number | 87912 |
Kakamigahara city Gifu Japan |
Telephone number | +81-58-389-1811 | Fax number | +81-58-389-1812 |
Employees | 8,000,000 JPY | Annual sales | |
Employees | 52 | Person in charge | Keizou Ohori |
Type of manufacturing | Machine tools / Industrial machinery / Transportation equipment | ||
Primary clients |
