Simultaneous 5-axis machining( Development and production of prototype/Small-scale production / Machining ) |
High precision( Mass production / Mechanical processing ) |
NC cylindrical grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
NC turning machining( Mass production / Mechanical processing ) |
Machining (horizontal)( Development and production of prototype/Small-scale production / NC machining ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
NC internal grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Company name |
株式会社 中村製作所 (Nakamuraseisakusho) |
Website URL | http://www.nakamuraseisakusyo.co.jp/ |
Street address |
Mie Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 55 |
Annual sales | Unregister | EMIDAS Member Number | 87696 |
Large | Medium | Small |
Material | Steel component distribution | Heavy plate Stainless steel Stainless steel pipe Flat steel plate Steel (round) bar Seamless steel pipe |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar Copper and brass products Titanium |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Gear hobber Thread-cutting Profile milling Straightening Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Nickel alloy Molybdenum alloy Machining (resin) Sintered metal Broaching Keyway milling Simultaneous 5-axis machining Milling (resin) Lathe machining (resin) Casting Titanium Sintered metal Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Additional-axis machining NC milling NC lathe machining 5-face/5-axis machining NC vertical lathe Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining 3-roll bending 3-roll bending (2 m or longer) Bending (hydraulic) Bending (servo) 3D pipe machining Can manufacturing (over 5 m) |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Cutting Electron beam machining Laser processing (longer than 121.2 m) CO2 laser machining Etching Microfabrication (laser machining ) Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Ceramic PI (polyimide) Other resins |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Cylindrical grinding Cylindrical mirror grinding Internal grinding NC internal grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Gear cutting machining Screw cutting machining Iron Stainless Cemented carbide Aluminum alloy Copper alloy Titanium alloy Molybdenum alloy Broaching machining Turning machining(plastic) Casting Honing machining Titanium High precision |
Mass production | Rubber | and other auto parts Medical Machine tools/Equipments Manufacturers |
Mass production | Forging | Hot forging Cold forging Upsetter forging Over 5 kg Ring forging Free forging |
Mass production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Cylindrical grinding Internal grinding NC internal grinding |
Surface treatment | Polishing/Lapping | Barrel finishing (rotation) Barrel finishing (centrifugal) Lap polishing Lap mirror polishing Single-face lapping and polishing Dual-face lapping and polishing Buffing |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Quenching Air quenching Vacuum quenching Austempering High frequency quenching Solution heat treatment Sub-zero treatment Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Buffing |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Assembly/Inspection | Inspection | Measuring |
Parts manufacturing | Machinery part | Shaft and roller manufacturing |
Product manufacturing | Plant equipment manufacturing | Marine vessel equipment manufacturing Hydro/thermal/electric/atomic power generation apparatus manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing Inspection and testing devices |
