"Ivy Spindle" Sales Service
Product Info
The "Ivy Spindle" is a high-speed rotating tool developed by Suzuki Precision for CNC automatic lathes, achieving a maximum rotation speed of 24,000 min-1. This innovative product does not require a dedicated controller or connection cables and can be easily swapped with existing rotary tool units by utilizing the machine's own power. This high-performance spindle significantly reduces machining time and improves manufacturing process efficiency. It enables high-precision machining in a wide range of applications, including fine hole drilling and small diameter end milling.
■ Features
- Easy replacement: Simply swap with the current rotary tool unit to achieve up to 4 times the speed
- High rotation speed: Achieves a maximum speed of 24,000 min-1, reducing machining time
- Runout precision: Runout accuracy within 3μm, ideal for fine machining and high-precision parts manufacturing
- Easy operation: No need for a controller or connection cables; uses the machine’s power for speed enhancement
- Versatility: Suitable for fine hole drilling, small diameter end milling, and precision parts machining
■ Specifications
- Maximum speed: 24,000 min-1
- Applications: Fine machining, small diameter end milling, high-precision parts machining
- Manufacturer: Suzuki Precision Co., Ltd.
■ Applications
- Efficiency improvement in fine machining processes using CNC automatic lathes
- High-precision parts machining using small diameter end mills
- Multi-product machining in short time aimed at improving productivity
- Manufacturing of parts for medical devices and precision equipment
The "Ivy Spindle," developed by Suzuki Precision to enhance production efficiency, is sold by F-1 Tools as the official distributor in Thailand. This product, enabling high-speed machining, supports the improvement of manufacturing productivity in the Thai manufacturing industry.
F-1 TOOLS CO., LTD. is based in Pathum Thani Province and provides services throughout Thailand.
■ For more details, download the PDF or feel free to contact us.
Contact: F-1 Tools (Ichihazama) +66-89-813-9076
CONTACT
This is the inquiry form for Thai Taiho Tech Co., Ltd.. Please enter your inquiry.
This service is intended to provide consultation and opinion requests for processing projects.
Please do not use this information for self-promotion or sales activities.
If we receive a complaint from a recipient about the contents of the transmission, we may take measures such as forcibly stopping the use of the service.
Inquiry Type*Required
Message*Required
Attach file
Only image (jpeg, jpg, gif, png, pdf) and compressed file (zip, lzh) extensions are valid. Maximum file size 10MB
