Laser and turret punch press processing ( Development and production of prototype/Small-scale production / Blank cutting ) |
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Copper/Aluminum( Development and production of prototype/Small-scale production / Blank cutting ) |
Thin plate (below 6 mm)( Development and production of prototype/Small-scale production / Blank cutting ) |
Thick plate (over 6 mm)( Development and production of prototype/Small-scale production / Blank cutting ) |
Stainless steel( Mass production / Metal press ) |
Bending( Mass production / Metal press ) |
Company name |
古川電気工業 株式会社 (Furukawadennkikougyou) |
Website URL | http://feit.co.jp/ |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 10 |
Annual sales | Unregister | EMIDAS Member Number | 86085 |
Type of manufacturing | Machine tools / Industrial machinery / Telecommunication equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Angle machining Deburring Coating Bending (hydraulic) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Laser and turret punch press processing Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Acrylic Other resins |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining NC data creation Drawing die Bending die Blanking die Progressive die Single press die 60 - 300 t Compound die |
Mass production | Metal press | Drawing Bending Iron Stainless steel Aluminum Copper Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Press robot (80 -200 t) Press robot (200 - 500 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Surface treatment | Plating/Chemical conversion treatment | Zinc (rack) Alumite (anode oxidation) Electroless nickel (barrel) Iron Copper Aluminum Magnesium Degreasing Hot-dip galvanizing (mid-size Black chromate (black/green) |
Surface treatment | Coating | Powder coating Resin coating Electrodeposition coating Electrostatic coating Acrylic coating Epoxy coating Metal coating Fluorine coating |
Assembly/Inspection | Assembly | Precision equipment assembly Office equipment assembly Construction component assembly |
