Aluminum alloy( Mass production / Mechanical processing ) |
Stainless( Mass production / Mechanical processing ) |
Iron( Mass production / Mechanical processing ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Bench lathe machining ( Development and production of prototype/Small-scale production / Machining ) |
Audio components( Auto parts manufacturing / Interior part ) |
Casting( Mass production / Mechanical processing ) |
Company name |
畑精密工業 株式会社 (Hataseimitsukougyoukabushikigaisha) |
Website URL | https://t-nakamura-hata.amebaownd.com/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 15 |
Annual sales | Unregister | EMIDAS Member Number | 84970 |
Type of manufacturing | Medical equipment / Audio-video equipment / Electronic parts |
Large | Medium | Small |
Designing | Product and part designing | Wooden product designing External design |
Designing | Jig and tool designing | General jig designing Mass production jig designing Automatic tool designing General-purpose jig designing |
Designing | Test | Investigative research |
Designing | Simulation | Casting Forging Plating Heat treatment Press Cutting Welding Resin |
Material | Steel component distribution | Stainless steel Shaped stainless steel Perforated metal Electroplated steel plate Free-machining steel Other steel plates and straps Flat steel plate Steel (round) bar |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Planer machining Deep hole drilling Rolling Thread-cutting Straightening Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Machining (resin) Broaching Keyway milling Automatic lathe Bench lathe machining Milling (resin) Air chuck equipment Lathe machining (resin) Casting Handles microfabrication Handles microfabrication pipe manufacturing Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Additional-axis machining NC milling NC lathe machining NC vertical lathe Combined lathe machining Machining (horizontal) Handles 3D processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Chassis manufacturing Deburring Coating |
Development and production of prototype/Small-scale production | Blank cutting | Cutting Etching Stainless steel Copper/Aluminum Precision cutting |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Cylindrical grinding Jig grinding Internal grinding Centerless grinding NC internal grinding Double-sided grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing Chassis prototype manufacturing Aluminum die-casting prototype mold |
Die manufacturing | Press die | Manufacturing Part processing NC data creation Drawing die Progressive die |
Die manufacturing | Forging die | Manufacturing Forging die part processing Cold forging die Press forging die Header die |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Complex turning machining Wire machining Rolling machining Screw cutting machining Micro-hole machining Electrical discharge machining Spinning Iron Stainless Aluminum alloy Copper alloy Titanium alloy Nickel alloy Broaching machining Automatic screw machining Air chuck equipment Turning machining(plastic) Casting Honing machining Titanium Ultra-thin High precision High strength |
Mass production | Forging | Header machining Cold forging Press forging |
Mass production | Blank cutting | Cutting process Etching Precision cutting |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Copper (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Rhodium Electroless copper (barrel) Nickel (rack) Tin (rack) Copper (rack) Gold/Silver plating Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Aldine treatment (aluminum chromate) Electroless nickel (barrel) Electroless copper (rack) Electroless nickel (rack) Chemical conversion coating Tin-zinc alloy plating (rack) Trivalent Chromate (barrel plating) Iron Copper Brass Zinc die-cast Aluminum Stainless steel Plastic Other anti-rust treatments Hard chromium (rack) Titanium Degreasing Black oxide finish Colored alumite Hard alumite Unichromate (white) Black chromate (black/green) Nickel (hoop) Gold(Hoop) Electroless nickel (large) Black nickel Hard chrome (barrel) Hard chrome (large) Tin (hoop) Hard alumite (large) |
Surface treatment | Cleaning | Hydrocarbon cleaning Trichlene cleaning Shower-type cleaning Ultrasonic cleaning |
Surface treatment | Coating | Air-spray coating Resin coating Wood coating Electrodeposition coating Electrostatic coating Urethane coating Acrylic coating Lacquer coating Epoxy coating Electrical insulating |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing Tool polishing Blade polishing Brush polishing Buffing Mirror polishing |
Surface treatment | Printing and others | NC engraving Engraving Printing Silk screen printing Offset printing Silk (handles curved surface) Pad printing Hot stamping (gold embossing) Gravure printing Laser engraving Direct printing |
Surface treatment | Heat treatment | Annealing Vacuum annealing Quenching Vacuum quenching High frequency quenching Flame quenching Nitridation |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Vacuum deposition Spattering Buffing Shot blast Sound blast Etching (surface treatment) |
Assembly/Inspection | Repair | Auto parts repair Die repair |
Assembly/Inspection | Inspection | Metal press Forging Casting Measuring |
Assembly/Inspection | Side job processing | Manual labor |
Parts manufacturing | Machinery part | Shaft and roller manufacturing pipe manufacturing Ring |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing Bolt manufacturing Nut manufacturing Screw manufacturing |
Parts manufacturing | Other parts | Blade manufacturing |
Auto parts manufacturing | Body part | Grill Other body parts |
Auto parts manufacturing | Drive system part | Steering device Drive shaft |
Auto parts manufacturing | Engine | Muffler Radiator parts |
Auto parts manufacturing | Interior part | Seat parts Audio components |
Product manufacturing | Production property | Stamp manufacturing Blade manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing Pipe connection Lavatory products manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing Cabinetmaking Interior manufacturing |
Product manufacturing | Craftwork/Event and ceremonial goods | Wooden product manufacturing |
Product manufacturing | Watch/Glasses/Accessory/Jewelry | Necklace and pendant manufacturing Bracelet and buckle manufacturing Jewerly parts manufacturing |
