板金・プレス加工をサポート。構成家具、陳列棚、機械部品、専用パレット等金属加工が得意で、パンチレーザー複合機、NCタレパン、プレス、ブレーキ、溶接、塗装、組付、梱包、完成品迄単品から量産加工可能です。
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Robot welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
TIG welding (argon welding)( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Turret punch press processing( Development and production of prototype/Small-scale production / Blank cutting ) |
Pipe machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Cutting( Development and production of prototype/Small-scale production / Blank cutting ) |
Shearing( Development and production of prototype/Small-scale production / Blank cutting ) |
Company name |
株式会社 コーポレーション金子 (Ko-pore-shonnkaneko) |
Website URL | http://www.corporation-kaneko.com/ |
Street address |
Gifu Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 45 |
Annual sales | Unregister | EMIDAS Member Number | 84380 |
Type of manufacturing | Audio-video equipment / Office automation equipment / Furniture |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Angle machining Pipe bending Deburring 3-roll bending Bending (hydraulic) Bending (servo) 3D pipe machining |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Corner shearing Thin plate (below 6 mm) Stainless steel Fiber laser processing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing Stud welding |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Brass Plated steel plate Stainless steel material for spring Thickness Thickness Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Mass production | Sheet-metal processing | NC set press Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Deburring process |
Product manufacturing | Production property | Machine tool manufacturing |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing |
