塩ビ配管部品500点以上の製作実績と、浄化槽用塩ビ部品一筋50年以上の加工技術に基づく塩ビ製品共同開発及び製品化への技術提案力でお客様のご要望の製品を製作します。
PVC (polyvinyl chloride)( Mass production / Plastic ) |
Plastic adhesive( Mass production / Welding / welding ) |
Welding( Development and production of prototype/Small-scale production / Prototype processing ) |
Plastic protocol machining( Development and production of prototype/Small-scale production / Prototype processing ) |
Router machining( Development and production of prototype/Small-scale production / Machining ) |
Cutting( Development and production of prototype/Small-scale production / Blank cutting ) |
Lathe machining (resin)( Development and production of prototype/Small-scale production / Machining ) |
Company name |
株式会社 宮田工業所 (Miyatakougyousho) |
Website URL | http://www.mcl-miyata.co.jp/ |
Street address |
Aichi Japan
[See map] |
Person in charge | - |
Capital | 50,000,000 JPY | Employees | 71 |
Annual sales | 1,200,000,000 JPY | EMIDAS Member Number | 83473 |
Large | Medium | Small |
Material | Plastic material distribution | PVC (polyvinyl chloride) |
Development and production of prototype/Small-scale production | Machining | General-purpose lathe machining Thread-cutting Router machining Lathe machining (resin) |
Development and production of prototype/Small-scale production | NC machining | NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Blank cutting | Cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Other resins |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Plastic bonding Ultrasonic welding Hot plate welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Welding Bending Porous plastic prototype |
Mass production | Mechanical processing | Machining Tapping machining Screw cutting machining Turning machining(plastic) |
Mass production | Plastic | PVC (polyvinyl chloride) General-purpose material Below 60 t 60 - 300 t Injection molding Handles small-scale production |
Mass production | Blank cutting | Thin plate 6 mm or less Other resins |
Mass production | Welding / welding | Plastic adhesive Hot plate welding |
Assembly/Inspection | Side job processing | Manual labor |
Parts manufacturing | Machinery part | Valve manufacturing Connection parts manufacturing pipe manufacturing |
Product manufacturing | Production property | Environmental equipment manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing Pipe connection Lavatory products manufacturing Water supply and discharge system manufacturing |
Product manufacturing | Environmental equipment manufacturing | Waste water treatment system manufacturing |
