Compression molding ( Mass production / Rubber ) |
Special shape extrusion molding( Mass production / Plastic ) |
High frequency welder processing( Mass production / Welding / welding ) |
Thermoset resin( Mass production / Plastic ) |
PPS (polyphenylene sulfide)( Mass production / Plastic ) |
Silicon rubber( Mass production / Rubber ) |
Rubber product prototype manufacturing( Mass production / Rubber ) |
Company name |
会津ゴム工業株式会社 (Aidugomukougyou) |
Website URL | http://www.aizugomu.co.jp/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 10 |
Annual sales | Unregister | EMIDAS Member Number | 81864 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Medical equipment |
Large | Medium | Small |
Material | Plastic material distribution | PPS (polyphenylene sulfide) PI (polyimide) PEEK (polyetheretherketone) Urethane resin PU (polyurethane) PES (polyethersulfone) |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Photoforming Punching Bending Vacuum injection molding Prototype/Small-lot molding Small-lot/Injection molding |
Die manufacturing | Plastic mold | Designing Manufacturing Injection molding die Blow molding die Vacuum/Air pressure molding die Extrusion molding die Insert molding die Outsert molding die Below 60 t 60 - 300 t Thermoset resin die |
Die manufacturing | Rubber mold | Designing Rubber mold part processing Compression molding die Transfer molding die Blanking die Packing-related products binoculars and optical products Home electrical appliances Light electrical/earthing rubber Medical |
Die manufacturing | Cutting dies | Thomson punch Cutting blade cutting die Corrosion blade cutting die |
Mass production | Mechanical processing | Machining NC turning machining Complex turning machining Urethane Sponge |
Mass production | Plastic | Blow molding Vacuum molding Extrusion molding Insert molding Outsert molding Air pressure molding PVC (polyvinyl chloride) PMMA (polymethyl methacrylate) Engineering plastic PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) PI (polyimide) PEEK (polyetheretherketone) Fluororesin Thermoset resin Urethane resin PU (polyurethane) Elastomer Below 60 t 60 - 300 t Injection molding PES (polyethersulfone) Handles small-scale production Thin wall molding Tube extrusion molding Special shape extrusion molding |
Mass production | Rubber | Rubber product prototype manufacturing Compression molding Transfer molding Blanking Silicon rubber Urethane rubber Butyl rubber NBR SBR CR EPT Fluoro-rubber Acrylic rubber Packing-related products Home electrical appliances Light electrical/earthing rubber Medical Press stamping Extrusion molding Thermostability Chemical proof Architecture |
Mass production | Welding / welding | Plastic adhesive High frequency welder processing Ultrasonic welding High frequency welding |
Surface treatment | Other surface treatment | Vacuum deposition Coating Teflon coating |
Assembly/Inspection | Side job processing | Manual labor |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing Dental products |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing |
