板金加工から溶接・塗装まで一貫生産。小ロットから量産まで柔軟に対応します。マシニングセンタでの機械加工を含む製品も対応可能です。自社製品のバリ取り機「メタルエステ」も取り扱っております。
Deburring ( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Pipe machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Welding( Development and production of prototype/Small-scale production / Prototype processing ) |
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Microfabrication (laser machining )( Development and production of prototype/Small-scale production / Blank cutting ) |
Small-size prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Laser and turret punch press processing ( Development and production of prototype/Small-scale production / Blank cutting ) |
Plant equipment manufacturing( Product manufacturing / Plant equipment manufacturing ) |
Air-conditioning equipment manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 エステーリンク (Esute-rinnku) |
Website URL | https://www.st-link.co.jp |
Street address |
Niigata Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 95 |
Annual sales | Unregister | EMIDAS Member Number | 81545 |
Type of manufacturing | Machine tools / Measuring machinery / Medical equipment |
Large | Medium | Small |
Designing | Industrial equipment designing | Carrier machine designing Industrial machinery designing |
Development and production of prototype/Small-scale production | Machining | General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Ceramic Titanium Brass |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Deburring Coating Mirror surface machining Hair line machining 3-roll bending 3-roll bending (2 m or longer) Bending (hydraulic) Can manufacturing (over 5 m) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Water jet cutter machining Corner shearing CO2 laser machining Laser marking Microfabrication (laser machining ) Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Acrylic Precision cutting 3D laser machining Fiber laser processing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Arc welding Robot welding Other bonding methods YAG laser machining Fiber welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing |
Mass production | Sheet-metal processing | Pipe processing Can-making Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Angle processing Deburring process Painting process Hairline processing 3-roll machine Bender processing (flood control) Can making (more than 5m) Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Blank cutting | Laser marking Turret punch punching Shirring Cutting process Laser processing (over 1.2m) Connor Shah CO2 laser processing Fiber laser processing Microfabrication (laser) Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum acrylic 3D laser |
Mass production | Welding / welding | CO2 welding Fiber welding TIG welding (argon welding) Robot welding YAG laser processing |
Surface treatment | Coating | Air-spray coating Powder coating Metal coating |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
