Most recent update: 2023-07-15
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Wire electric discharge machining( Development and production of prototype/Small-scale production / Electrical discharge machine ) |
Plane grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Company name |
IHP・エンジェルオートメーション(日本支店) (Ennjeruo-tome-shonn) |
Website URL | http://ihp-precise.com/cn/index.asp |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 12,000,000 JPY | Employees | 32 |
Annual sales | 340,000,000 JPY | EMIDAS Member Number | 81400 |
Type of manufacturing | Jigs and tools / Industrial machinery / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron High rigid material Aluminum alloy Copper alloy Machining (resin) Keyway milling Shaper machining Milling (resin) Lathe machining (resin) Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Boring milling NC facing Machining (horizontal) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Coating Hair line machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding |
Die manufacturing | Press die | Designing Manufacturing Part processing Bending die Blanking die |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Injection molding die |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Zinc (barrel) Chromate (general) Rhodium Nickel (rack) Gold/Silver plating Chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Electroless nickel (barrel) Electroless nickel (rack) Iron Copper Brass Aluminum Stainless steel Hard chromium (rack) Black oxide finish Colored alumite Hard alumite Unichromate (white) Colored chromate (multi-color) |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Heat treatment | Quenching Air quenching Vacuum quenching High frequency quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Carbide Dispersion/TD Buffing DLC coating |
