鉄・鋳物・非鉄金属など多種の機械加工を行っております。特に鋳物加工を得意とし、1個の試作品から1000個の量産品、特急品も対応します。加工サイズは旋盤は360、マシニングは600まで加工可能です。
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
General-purpose lathe machining( Development and production of prototype/Small-scale production / Machining ) |
Casting( Mass production / Mechanical processing ) |
5-face/5-axis machining( Development and production of prototype/Small-scale production / NC machining ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
NC plane grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Company name |
有限会社 ヤマト (Yamato) |
Website URL | http://www.yamato-limited.jp/ |
Street address |
Gifu Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 7 |
Annual sales | Unregister | EMIDAS Member Number | 81246 |
Type of manufacturing | Transportation equipment / Machine tools / Industrial machinery |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Gear hobber Thread-cutting Straightening Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Molybdenum alloy Machining (resin) Sintered metal Keyway milling Automatic lathe Simultaneous 5-axis machining Milling (resin) Lathe machining (resin) Casting Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Cylindrical grinding Internal grinding Gear grinding |
Development and production of prototype/Small-scale production | Prototype processing | Welding Small-size prototype manufacturing Aluminum die-casting |
Mass production | Mechanical processing | Machining NC turning machining Five-face/axes machining Iron Stainless Aluminum alloy Copper alloy Molybdenum alloy Automatic screw machining Turning machining(plastic) Casting |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Nickel (rack) Electroless nickel (rack) Trivalent Chromate (barrel plating) Hard chromium (rack) Black oxide finish Unichromate (white) Black chromate (black/green) |
Surface treatment | Coating | Powder coating |
Surface treatment | Polishing/Lapping | Buffing |
Surface treatment | Heat treatment | Normalizing Straightening annealing Vacuum quenching High frequency quenching Carburized quenching |
Parts manufacturing | Machinery part | Connection parts manufacturing Shaft and roller manufacturing |
