Most recent update: 2023-10-06
Laser and turret punch punching( Mass production / Blank cutting ) |
Company name |
石原工作 株式会社 (Ishiharakousaku) |
Website URL | https://ishiharakousaku.com/ |
Street address |
Hiroshima Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 89 |
Annual sales | Unregister | EMIDAS Member Number | 80886 |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (auto) Drawing metal press die designing Transfer press die designing General metal press die 3D modeling (press) NC data creation (press) |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Designing | Test | Specimen processing Destructive test |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Broaching Keyway milling Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Precision sheet metal machining Sheet metal protocol manufacturing Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Laser and turret punch press processing Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) CO2 laser machining Laser marking Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Acrylic 3D laser machining Fiber laser processing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Arc welding Robot welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending |
Development and production of prototype/Small-scale production | Blank cutting | Laser marking Turret punch punching Shirring Cutting process Laser and turret punch punching Laser processing (over 1.2m) Shirring (more than 1.2m) Fiber laser processing 3D laser |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation 3D modeling Drawing die Bending die Blanking die Forming die Multi forming die Shaving die Progressive die Transfer press die Single press die Press robot die Over 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Forming Multi forming Shaving Coining Iron Stainless steel Aluminum Phosphor bronze Plated steel plate Thickness Thickness welding Tap processing crimp Single press (below 80 t) barrel Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (200 - 500 t) |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Wire machining Electrical discharge machining Iron Stainless Aluminum alloy Casting |
Mass production | Grinding processing | NC plane grinding NC internal grinding |
Mass production | Sheet-metal processing | Can-making Sheet metal prototype manufacturing Bending process |
Mass production | Blank cutting | Laser marking Turret punch punching Shirring Cutting process Laser and turret punch punching Laser processing (over 1.2m) Shirring (more than 1.2m) Fiber laser processing 3D laser |
Mass production | Welding / welding | Spot welding TIG welding (argon welding) Arc welding |
Surface treatment | Cleaning | Trichlene cleaning |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Assembly/Inspection | Assembly | Construction component assembly |
Assembly/Inspection | Repair | Die repair |
Assembly/Inspection | Inspection | Metal press |
Assembly/Inspection | Side job processing | Manual labor |
Parts manufacturing | Machinery part | Mechanical parts |
