Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
CO2 laser machining ( Development and production of prototype/Small-scale production / Blank cutting ) |
Fiber laser processing( Mass production / Blank cutting ) |
Bending process( Mass production / Sheet-metal processing ) |
TIG welding (argon welding)( Mass production / Welding / welding ) |
Thin plate 6 mm or less( Mass production / Blank cutting ) |
YAG laser machining( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Company name |
株式会社 大野社 九州工場 (Oonosha kyuushuukoujou) |
Website URL | https://www.ohnosha.co.jp/ |
Street address |
Nagasaki Japan
[See map] |
Person in charge | - |
Capital | 30,000,000 JPY | Employees | 30 |
Annual sales | 300,000,000 JPY | EMIDAS Member Number | 80713 |
Type of manufacturing | Heavy electric machinery / Jigs and tools / Industrial machinery |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Lathe machining (resin) |
Development and production of prototype/Small-scale production | NC machining | NC milling NC lathe machining Combined lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Bending (over 3.0 m) Angle machining 3-roll bending Bending (hydraulic) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting Shearing (longer than 121.2 m) Corner shearing CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Acrylic Fiber laser processing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) YAG laser machining |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending |
Mass production | Mechanical processing | NC milling machining NC turning machining Complex turning machining Iron Stainless Aluminum alloy Copper alloy Turning machining(plastic) |
Mass production | Rubber | Blanking Silicon rubber Urethane rubber NBR CR EPT Fluoro-rubber Packing-related products Press stamping |
Mass production | Sheet-metal processing | Pipe processing Can-making Precision sheet metal processing Sheet metal prototype manufacturing Angle processing Bender processing (flood control) Bending process |
Mass production | Blank cutting | Laser marking YAG laser processing Cutting process Laser processing (over 1.2m) CO2 laser processing Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum acrylic |
Mass production | Welding / welding | CO2 welding Spot welding TIG welding (argon welding) YAG laser processing |
