Automobile (mass production)
Turbine housing,DIN, Sutenresu,1.4848
Part name:Turbine housing(SUV)
Material:DIN, Sutenresu,1.4848
Weight:6kg
Outside dimension:450mm×250mm×200mm
Process:Machining processing、Turning、Leak test、Bush press fit
Monthly production:200 units
Product features
・Turbine housings are products with many work processes from machining, turning, leaks, and bush press fitting.
・Since the turbine housing is a product with a complicated shape and the place to clamp is limited, we work by a method that reduces distortion and deformation after processing. Also, since the material is "stainless steel 1.4848", work hardening easily occurs, and we worked with cooperating tool manufacturers on tool selection and conditions, from prototype to mass production.
・Due to the irregular shape, deburring work in complicated places after processing was done manually, and technology was required.
・We have worked with difficult-to-cut materials such as SUS turbine housings, and are prone to work hardening. For this product, we worked together with tool manufacturers to select tools, set processing conditions and extend tool life.
・We have experience with general engine parts as well as difficult-to-cut materials, and we can handle small lots of less than 100 pieces/month to 5000 pieces/month.
・We can handle products with many processes such as general-purpose machining, turning, leaking, and bush press-fitting.
・We have a proven track record of suppressing distortion/deformation after machining even for complex shapes and unbalanced shapes.
・Difficult-to-cut materials such as SUS cast steel are highly tenacious and easily produce burrs after machining. Therefore, determine the machining conditions that facilitate deburring work and set the trajectory of the cutting tool.
・We also have a track record of trial production of various materials, 4 types of aluminum castings, 6 types of cast iron, 10 types of steel (steel) and mass production.
・As a major manufacturer "tier1", we have also been involved in quality building and auditing.
Company name | Takenaka Co., Ltd. | EMIDAS Member Number | 80611 |
Sano Tochigi Japan |
Telephone number | +81-283-23-2633 | Fax number | +81-283-22-7055 |
Employees | 53,000,000 JPY | Annual sales | |
Employees | 152 | Person in charge | yonehara |
Type of manufacturing | Transportation equipment / Heavy electric machinery |
