Most recent update: 2024-03-07
Combined lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
株式会社 SPEEG (Supi-gu) |
Website URL | https://www.speeg.co.jp |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 15 |
Annual sales | Unregister | EMIDAS Member Number | 80488 |
Type of manufacturing | Jigs and tools / Industrial machinery / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Machining (resin) Broaching Keyway milling Automatic lathe Milling (resin) Lathe machining (resin) Casting Honing Titanium Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining Five-face machining Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Cylindrical grinding Centerless grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Aluminum die-casting |
Mass production | Mechanical processing | Machining NC turning machining Tapping machining Complex turning machining Screw cutting machining Iron Stainless Aluminum alloy Copper alloy Titanium alloy Automatic screw machining Turning machining(plastic) Casting Titanium |
Mass production | Plastic | Extrusion molding PVC (polyvinyl chloride) Fluororesin Urethane resin PU (polyurethane) Below 60 t Injection molding |
Mass production | Rubber | Rubber product prototype manufacturing Silicon rubber Urethane rubber Fluoro-rubber Home electrical appliances Light electrical/earthing rubber Press stamping Weight saving Thermostability Machine tools/Equipments Architecture Injection molding |
Mass production | Die-casting | 125 - 250 t Aluminum |
Mass production | Casting | Lost-wax Low-pressure casting Sand casting Cast-iron Ductile cast iron Cast steel Aluminum alloy 500 g and below Over 500 g and less than 5 kg 5 kg and over |
Mass production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Jig grinding Internal grinding Rotary grinding |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Chromate (general) Nickel (rack) Chromium (rack) Alumite (anode oxidation) Acid pickling Aldine treatment (aluminum chromate) Electroless nickel (barrel) Electroless nickel (rack) Trivalent Chromate (barrel plating) Iron Brass Aluminum Hard chromium (rack) Degreasing Black oxide finish Colored alumite Hard alumite Unichromate (white) Black chromate (black/green) Hard chrome (barrel) |
Surface treatment | Heat treatment | Normalizing Annealing Quenching Vacuum quenching High frequency quenching Carburized quenching Nitridation |
Assembly/Inspection | Inspection | Measuring |
Parts manufacturing | Machinery part | Valve manufacturing Vacuum components manufacturing Optical parts manufacturing |
