Most recent update: 2022-03-01
Thin wall (Thickness: 0.5 or less)/small-size sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 田中商店 (Tanakashoutenn) |
Website URL | http://www.tanaka-syouten.co.jp/ |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 4 |
Annual sales | 100,000,000 JPY | EMIDAS Member Number | 79831 |
Type of manufacturing | Construction material / Kitchen / Furniture |
Large | Medium | Small |
Material | Steel component distribution | Pickled steel plate Heavy plate Stainless steel Shaped stainless steel Stainless steel spring Perforated metal Expanded metal Stainless steel pipe Cold-rolled steel plate Electroplated steel plate Hot-dipped steel plate Colored steel plate Tin Chequered plate Tool steel Spring steel Free-machining steel Other steel plates and straps Shaped steel Flat steel plate Steel (round) bar Wires Other shaped steel bars Seamless steel pipe Welded steel pipe Rectangular steel pipe Drawn steel pipe Deck plate Roof deck Galvanized steel sheet Other steel pipes rolling |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar Steel bars and shapes Copper and brass products Pipe material Coils Others |
Material | Plastic material distribution | PVC (polyvinyl chloride) PMMA (polymethyl methacrylate) PC (polycarbonate) FRP (fiber reinforced plastic) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Kitchen unit manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining Bending (hydraulic) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Arc welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Parts manufacturing | Other parts | Sign board manufacturing Metallic mesh manufacturing |
Product manufacturing | Production property | Freezer equipment manufacturing Food industry machinery manufacturing |
Product manufacturing | Household commodity | Bath products manufacturing Storage products |
Product manufacturing | Furniture/Interior | Nameplates |
