関西を拠点に 関東方面から 西日本での営業展開しており
製缶 板金 切削加工など 金属加工を社内 商社として得意とした企業です
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
NC milling ( Development and production of prototype/Small-scale production / NC machining ) |
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
General-purpose lathe machining( Development and production of prototype/Small-scale production / Machining ) |
Aluminum alloy( Development and production of prototype/Small-scale production / Machining ) |
TIG welding (argon welding)( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Chassis manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 津島鉄工所 (Tsushimatekkousho ) |
Website URL | http://www.tsm-tk.com/ |
Street address |
Kyoto Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 32 |
Annual sales | 600,000,000 JPY | EMIDAS Member Number | 79055 |
Type of manufacturing | Jigs and tools / Industrial machinery / Transportation equipment |
Large | Medium | Small |
Material | Steel component distribution | Pickled steel plate Heavy plate Stainless steel Shaped stainless steel Stainless steel spring Perforated metal Expanded metal Stainless steel pipe Hot-rolled steel plate Cold-rolled steel plate Electroplated steel plate Hot-dipped steel plate Colored steel plate Chequered plate Spring steel Other steel plates and straps Shaped steel Flat steel plate Steel (round) bar Seamless steel pipe Welded steel pipe Drawn steel pipe Steel forgings Steel castings Other steel pipes rolling |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar Steel bars and shapes Copper and brass products Titanium Pipe material Others rolling Aluminum extrusions |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Laser processing (longer than 121.2 m) CO2 laser machining Nitrogen cutting Thick plate (over 6 mm) Stainless steel Precision cutting |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding Projection welding |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Chassis prototype manufacturing |
Mass production | Welding / welding | Robot welding |
