Complex turning machining( Mass production / Mechanical processing ) |
NC turning machining( Mass production / Mechanical processing ) |
Combined lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Automatic screw machining( Mass production / Mechanical processing ) |
Stainless( Mass production / Mechanical processing ) |
Aluminum alloy( Mass production / Mechanical processing ) |
Handles mass production( Parts manufacturing / Electric board and electronic part ) |
Company name |
株式会社 飛沢製作所 (Tobisawaseisakusho) |
Website URL | http://www.tobisawa.co.jp |
Street address |
Fukushima Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 45 |
Annual sales | Unregister | EMIDAS Member Number | 78862 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Rolling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Nickel alloy Molybdenum alloy Automatic lathe Bench lathe machining Lathe machining (resin) Casting Handles microfabrication |
Development and production of prototype/Small-scale production | NC machining | NC milling NC lathe machining Combined lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Micro hole machining |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing Aluminum die-casting |
Mass production | Mechanical processing | NC turning machining Complex turning machining Iron Stainless Aluminum alloy Copper alloy Automatic screw machining Fine particle material accepted |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Copper (barrel) Chromium (barrel) Zinc (barrel) Chromate (general) Electroless copper (barrel) Nickel (rack) Gold/Silver plating Chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Parkerizing (phosphate film) Electroless nickel (barrel) Electroless nickel (rack) Baking (hydrogen embrittling) Trivalent Chromate (barrel plating) Iron Copper Brass Aluminum Stainless steel Hard chromium (rack) Degreasing Black oxide finish Colored alumite Hard alumite Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing |
Surface treatment | Heat treatment | Annealing Quenching Salt bath quenching Vacuum quenching High frequency quenching Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (centrifugal) |
Parts manufacturing | Machinery part | Vacuum components manufacturing Connection parts manufacturing Crank shaft manufacturing Optical parts manufacturing Shaft and roller manufacturing Measurement devices manufacturing |
Parts manufacturing | Electrical part | Connector manufacturing Other electrical part manufacturing |
Parts manufacturing | Electric board and electronic part | Handles mass production Handles short delivery |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing Nut manufacturing Screw manufacturing |
Auto parts manufacturing | Interior part | Communication accessories Audio components |
Product manufacturing | Production property | Electrical machinery and apparatus manufacturing Optical products manufacturing Information equipment manufacturing Monitoring device manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing |
Product manufacturing | Others | Telecommunication equipment manufacturing |
