Most recent update: 2023-06-30
Company name |
株式会社 サンキャスト (Sannkyasuto) |
Website URL | http://www.suncast.co.jp |
Street address |
Ibaraki Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 68 |
Annual sales | 2,000,000,000 JPY | EMIDAS Member Number | 78216 |
Type of manufacturing | Audio-video equipment / Telecommunication equipment / Transportation equipment |
Large | Medium | Small |
Designing | Mold designing | Casting die designing Injection molding die |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Aluminum alloy Magnesium alloy Automatic lathe |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining Combined lathe machining Handles 3D processing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Die manufacturing | Casting die | Designing Manufacturing Die-casting part processing Die-casting die |
Mass production | Die-casting | 125 t or less 125 - 250 t 000 t Aluminum Magnesium alloy |
Mass production | Casting | Aluminum alloy Magnesium alloy Over 500 g and less than 5 kg |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Alumite (anode oxidation) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (rack) Chemical conversion coating Tin-zinc alloy plating (rack) Baking (hydrogen embrittling) Trivalent Chromate (barrel plating) Zinc die-cast Aluminum Other anti-rust treatments Magnesium Degreasing Black oxide finish Colored alumite Hard alumite Dacrotizing Black chromate (black/green) |
Surface treatment | Coating | Electrodeposition coating Electrostatic coating UV resistant coating Melamine coating Urethane coating Acrylic coating Epoxy coating Heat-resistant coating |
Surface treatment | Polishing/Lapping | Chemical polishing Brush polishing |
Surface treatment | Printing and others | Silk (handles curved surface) Hot stamping (gold embossing) |
Surface treatment | Heat treatment | Straightening annealing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Vacuum deposition Buffing Shot blast Glass beads blast Etching (surface treatment) |
Assembly/Inspection | Inspection | Casting Measuring |
