Aluminum( Mass production / Metal press ) |
Aluminum alloy( Development and production of prototype/Small-scale production / Machining ) |
Pipe machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Cutting( Development and production of prototype/Small-scale production / Blank cutting ) |
Hair line machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Bending( Mass production / Metal press ) |
Stainless steel( Mass production / Metal press ) |
Company name |
株式会社 富士商会 (Fujishoukai) |
Website URL | https://www.fuji4186.co.jp/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 40,000,000 JPY | Employees | 30 |
Annual sales | Unregister | EMIDAS Member Number | 78005 |
Type of manufacturing | Measuring machinery / Construction material / Transportation equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Stainless steel Aluminum alloy Magnesium alloy Titanium alloy |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining Coating Hair line machining Bending (hydraulic) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending |
Mass production | Metal press | Drawing Bending Blanking Stainless steel Aluminum Titanium Stainless steel material for spring Thickness Thickness Diameter φ0.6mm - φ9.0mm Combined press-joining Hydraulic counter pressure press |
Surface treatment | Plating/Chemical conversion treatment | Alumite (anode oxidation) Chemical conversion coating Aluminum Stainless steel Titanium Magnesium Colored alumite Hard alumite |
Surface treatment | Coating | Electrodeposition coating Metal coating |
Surface treatment | Other surface treatment | Coating Shot blast Etching (surface treatment) Ionized plating |
Parts manufacturing | Spring | Thin leaf spring Leaf spring Stainless steel Diameter Diameter |
Parts manufacturing | Other parts | Sign board manufacturing Metallic mesh manufacturing |
