Most recent update: 2023-04-24
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Small-size prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 浜野製作所 (Hamanoseisakusho) |
Website URL | http://www.hamano-products.co.jp/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 50 |
Annual sales | Unregister | EMIDAS Member Number | 77425 |
Type of manufacturing | Jigs and tools / Industrial machinery |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Spinning |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Deburring Coating Mirror surface machining 3-roll bending Bending (hydraulic) Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Laser and turret punch press processing CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Drawing die Bending die Blanking die Shaving die Single press die Compound die |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Brass Phosphor bronze Thickness Thickness φ0.6mm - φ9.0mm Diameter Single press (below 80 t) |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Chromate (general) Nickel (rack) Chromium (rack) Alumite (anode oxidation) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (barrel) Electroless copper (rack) Electroless nickel (rack) Tin-zinc alloy plating (rack) Baking (hydrogen embrittling) Trivalent Chromate (barrel plating) Hard chromium (rack) Degreasing Black oxide finish Colored alumite Hard alumite Hot-dip galvanizing (small-size Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Coating | Resin coating Electrodeposition coating Urethane coating Acrylic coating Lacquer coating Electrical insulating Metal coating |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Printing and others | Engraving Silk screen printing |
Surface treatment | Heat treatment | Salt bath soft nitriding (tufftriding) Nitridation |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Teflon coating Buffing Shot blast Etching (surface treatment) Thermal oxidation |
Assembly/Inspection | Assembly | Industrial machinery assembly |
