Most recent update: 2023-04-21
Drawing( Mass production / Metal press ) |
Company name |
協立工業 株式会社 (Kyouritsukougyou) |
Website URL | http://www.kyoritsu-press.com/ |
Street address |
Niigata Japan
[See map] |
Person in charge | - |
Capital | 54,600,000 JPY | Employees | 35 |
Annual sales | 800,000,000 JPY | EMIDAS Member Number | 77401 |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining NC set press Sheet metal protocol manufacturing Bending (over 3.0 m) Pipe bending Coating Mirror surface machining 3-roll bending Bending (hydraulic) 3D pipe machining |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Corner shearing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Seam welding Arc welding Robot welding Brazing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Part processing Drawing die Bending die Blanking die Forming die Progressive die Transfer press die Single press die Below 60 t 60 - 300 t Over 300 t |
Mass production | Metal press | Drawing Bending Blanking Forming Iron Stainless steel Aluminum Titanium Plated steel plate Thickness Thickness Thickness Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Acid pickling Baking (hydrogen embrittling) Trivalent Chromate (barrel plating) Degreasing Hot-dip galvanizing (small-size Unichromate (white) Black chromate (black/green) |
Surface treatment | Coating | Powder coating Electrodeposition coating |
Surface treatment | Heat treatment | High frequency quenching Carburized quenching Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Assembly/Inspection | Assembly | Auto parts assembly |
Assembly/Inspection | Inspection | Metal press |
Product manufacturing | Construction and civil engineering machinery manufacturing | Combustor manufacturing |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing |
