液晶製造装置、リチウム電池関連、装置各種産業装置の設計・製作に実績があります。2棟の大型クリーン組立工場を保有し、社内一貫生産が可能な他、大型設備を保有し、機械加工、溶接、塗装、組立、が対応可能です。
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Industrial machinery designing( Designing / Industrial equipment designing ) |
Energy-saving equipment/Automatic instrument manufacturing( Product manufacturing / Production property ) |
Semiconductor manufacturing equipment manufacturing( Product manufacturing / Production property ) |
General jig manufacturing( Development and production of prototype/Small-scale production / Jig manufacturing ) |
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Industrial machinery assembly( Assembly/Inspection / Assembly ) |
Specimen processing( Designing / Test ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
鈴木機械 株式会社 (Suzukikikai) |
Website URL | http://www.szk-rm.co.jp |
Street address |
Iwate Japan
[See map] |
Person in charge | - |
Capital | 63,000,000 JPY | Employees | 70 |
Annual sales | Unregister | EMIDAS Member Number | 77250 |
Type of manufacturing | Jigs and tools / Industrial machinery / Electronic parts |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing Automatic tool designing General-purpose jig designing |
Designing | Test | Specimen processing |
Designing | Industrial equipment designing | Automatic machinery manufacturing Carrier machine designing Precision automatic machinery designing Industrial machinery designing Energy-saving machinery designing |
Designing | Simulation | 3D modeling |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Gear hobber Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Machining (resin) Keyway milling Automatic lathe Lathe machining (resin) Casting Titanium Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Additional-axis machining NC milling NC lathe machining Boring milling Machining (horizontal) Handles 2.5-dimensional processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Chassis manufacturing Can manufacturing (over 5 m) |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Cylindrical grinding Internal grinding NC internal grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Arc welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Aluminum die-casting |
Die manufacturing | Press die | Manufacturing Part processing Die set machining Below 60 t 60 - 300 t |
Assembly/Inspection | Assembly | Precision equipment assembly Auto parts assembly Industrial machinery assembly |
Assembly/Inspection | Repair | Precision equipment repair Auto parts repair Industrial machinery repair Machine tool repair |
Parts manufacturing | Machinery part | Vacuum components manufacturing Pressure container manufacturing Shaft and roller manufacturing |
Parts manufacturing | Electrical part | Harness processing |
Product manufacturing | Production property | Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Measurement/testing devices manufacturing Freezer equipment manufacturing Vacuum equipment manufacturing Hydraulic pressure equipment manufacturing Chemical industry machinery and equipment manufacturing Fluid equipment manufacturing Stamp manufacturing Semiconductor manufacturing equipment manufacturing LCD manufacturing |
