Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
NC milling ( Development and production of prototype/Small-scale production / NC machining ) |
5-face/5-axis machining( Development and production of prototype/Small-scale production / NC machining ) |
NC vertical lathe ( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
株式会社松山機型工業 (Matsuyamakigatakougyou) |
Website URL | http://www.matsuyamakigata.co.jp/ |
Street address |
Ehime Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 159 |
Annual sales | Unregister | EMIDAS Member Number | 77153 |
Type of manufacturing | Machine tools / Industrial machinery / Electronic parts |
Large | Medium | Small |
Designing | Simulation | 3D modeling CAE fluid analysis Casting Cutting Resin |
Designing | Data creation (3D scan) | 3D printer Data creation (3D scan) |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Plano miller machining Machining/Handles small-scale production (order from 1 piece) Keyway milling Simultaneous 5-axis machining Milling (resin) Lathe machining (resin) Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Five-face machining NC facing NC vertical lathe Combined lathe machining Machining (horizontal) Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Casting | Shell moulding Low-pressure casting Gravity casting Sand casting Cast-iron Ductile cast iron Aluminum alloy Over 500 g and less than 5 kg 5 kg and over 100kg - 500kg 500 kg or more |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Profile grinding NC internal grinding |
Development and production of prototype/Small-scale production | Prototype processing | Chassis prototype manufacturing Model manufacturing Aluminum die-casting |
Die manufacturing | Casting die | Designing Manufacturing NC data creation 3D modeling Shell moulding die Wooden model |
Mass production | Mechanical processing | Machining Five-face/axes machining Wire machining Screw cutting machining |
Mass production | Die-casting | 000 t Aluminum |
Mass production | Casting | Shell moulding Low-pressure casting Gravity casting Sand casting Cast-iron Ductile cast iron Aluminum alloy Over 500 g and less than 5 kg 5 kg and over 100kg - 500kg 500 kg or more |
Assembly/Inspection | Inspection | Measuring |
Auto parts manufacturing | Drive system part | Clutch Transmission |
Auto parts manufacturing | Engine | Cooling system Ignition system Fuel system |
Product manufacturing | Machinery and product manufacturing | Paper product manufacturing |
