Most recent update: 2015-09-17
Company name |
有限会社 エム・エス・ピー (Emuesupi-) |
Website URL | http://msp-shirakawa.com/ |
Street address |
Fukushima Japan
[See map] |
Person in charge | - |
Capital | 30,000,000 JPY | Employees | 18 |
Annual sales | Unregister | EMIDAS Member Number | 77020 |
Type of manufacturing | Industrial machinery / Measuring machinery / Jigs and tools |
Large | Medium | Small |
Designing | Product and part designing | Medical equipment designing Measurement/testing device designing |
Designing | Jig and tool designing | General jig designing |
Designing | Industrial equipment designing | Automatic machinery manufacturing Industrial machinery designing Food industry machinery designing Energy-saving machinery designing |
Designing | Electrical planning | Electrical machinery and apparatus designing |
Development and production of prototype/Small-scale production | Machining | Planer machining Gear hobber Thread-cutting Spinning Machining/Handles small-scale production (order from 1 piece) Stainless steel Aluminum alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Machining (resin) Keyway milling Automatic lathe Shaper machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining NC vertical lathe Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Corner shearing |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Jig grinding Thread grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Arc welding Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining |
Mass production | Metal press | Drawing Iron Stainless steel Aluminum Phosphor bronze Stainless steel material for spring Thickness Thickness Thickness |
Mass production | Plastic | PVC (polyvinyl chloride) General-purpose material PMMA (polymethyl methacrylate) PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) PI (polyimide) PEEK (polyetheretherketone) Fluororesin Urethane resin PU (polyurethane) PES (polyethersulfone) EP (epoxy) |
Mass production | Rubber | Rubber product prototype manufacturing Silicon rubber Urethane rubber NBR SBR |
Surface treatment | Plating/Chemical conversion treatment | Acid pickling Electroless nickel (barrel) Electroless nickel (rack) Hard chromium (rack) Colored alumite Hard alumite |
Surface treatment | Coating | Air-spray coating Urethane coating |
Surface treatment | Polishing/Lapping | Barrel finishing (vibration) Blade polishing |
Surface treatment | Heat treatment | Quenching High frequency quenching |
Surface treatment | Other surface treatment | Sound blast |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Assembly/Inspection | Repair | Precision equipment repair Industrial machinery repair |
Parts manufacturing | Machinery part | Shaft and roller manufacturing |
Parts manufacturing | Electric board and electronic part | Electronic parts assembly and wiring |
Parts manufacturing | Spring | Torsion spring Stainless steel Diameter Diameter |
Product manufacturing | Production property | Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Measurement/testing devices manufacturing Food industry machinery manufacturing Industrial robot manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing |
