Most recent update: 2023-02-01
Progressive press (80 - 200 t)( Mass production / Metal press ) |
Transfer press (80 - 200 t)( Mass production / Metal press ) |
Insert molding( Mass production / Plastic ) |
Company name |
型研精工 株式会社 (Katakennseikou) |
Website URL | https://kataken-web.com/jp/ |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 100,000,000 JPY | Employees | 200 |
Annual sales | Unregister | EMIDAS Member Number | 76945 |
Type of manufacturing | Telecommunication equipment / Electronic parts / Electrical component for transportation equipment |
Large | Medium | Small |
Designing | Mold designing | Injection molding die Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing Transfer press die designing General metal press die |
Designing | Industrial equipment designing | Carrier machine designing Precision automatic machinery designing |
Development and production of prototype/Small-scale production | Machining | Iron Stainless steel High rigid material Aluminum alloy Copper alloy Nickel alloy Ceramic Sintered metal |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Machining (horizontal) Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | Profile grinding Jig boring Jig grinding |
Die manufacturing | Press die | Designing Manufacturing Drawing die Bending die Blanking die Forming die Progressive die Transfer press die Single press die Below 60 t 60 - 300 t Over 300 t Compound die |
Die manufacturing | Plastic mold | Designing Manufacturing Injection molding die Insert molding die Below 60 t 60 - 300 t Thin wall injection molding die Injection molding die for microfabrication (5 mm or smaller) |
Mass production | Metal press | Drawing Bending Blanking Forming Shaving Coining Transfer press (below 80 t) Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Thickness Diameter φ0.6mm - φ9.0mm Diameter Combined press-joining Transfer press (80 - 200 t) Transfer press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Mass production | Plastic | Insert molding General-purpose material PMMA (polymethyl methacrylate) Engineering plastic PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) PI (polyimide) GFRP (glass fiber reinforced plastic) Below 60 t 60 - 300 t Injection molding PES (polyethersulfone) Thin wall molding |
Assembly/Inspection | Assembly | Auto parts assembly |
Parts manufacturing | Electrical part | Connector manufacturing Other electrical part manufacturing Switch manufacturing |
Auto parts manufacturing | Interior part | Communication accessories |
Product manufacturing | Production property | Carrier machine manufacturing |
