Most recent update: 2023-09-28
Machining( Mass production / Mechanical processing ) |
Handles 3D processing( Development and production of prototype/Small-scale production / NC machining ) |
5-face/5-axis machining( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
株式会社 マテリアル (Materiaru) |
Website URL | https://www.material-web.net |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 20,010,000 JPY | Employees | 40 |
Annual sales | Unregister | EMIDAS Member Number | 76866 |
Type of manufacturing | Telecommunication equipment / Electronic parts |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing Mass production jig designing General-purpose jig designing |
Designing | Data creation (3D scan) | Data creation (3D scan) |
Material | Steel component distribution | Heavy plate Stainless steel Shaped stainless steel Hot-rolled steel plate Cold-rolled steel plate Flat steel plate |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar Copper and brass products Pipe material Others Aluminum extrusions |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Gear hobber Iron Stainless steel Aluminum alloy Copper alloy Keyway milling Automatic lathe Bench lathe machining Milling (resin) Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Five-face machining NC vertical lathe Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Profile grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Five-face/axes machining Complex turning machining Wire machining Iron Stainless Aluminum alloy Copper alloy Nickel alloy |
Surface treatment | Plating/Chemical conversion treatment | Alumite (anode oxidation) Acid pickling Aldine treatment (aluminum chromate) Electroless nickel (barrel) Electroless nickel (rack) Iron Aluminum Stainless steel Black oxide finish Colored alumite Hard alumite Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Coating | Electrodeposition coating Urethane coating Acrylic coating Metal coating |
Surface treatment | Printing and others | Engraving Silk screen printing Laser engraving |
Assembly/Inspection | Inspection | Measuring |
Parts manufacturing | Machinery part | Mechanical parts |
